MartinA. Posted August 8, 2021 Report Share Posted August 8, 2021 Hi, I need help. The display on the vehicle sometimes starts flashing after starting and at the same time the parking assist does not work. Does anyone have an idea? Thank you Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted August 8, 2021 Report Share Posted August 8, 2021 First Next, start by having your battery and alternator properly load tested. One or the other being bad is a very common reason for flashing and/or electrical symptoms. Many threads here one this. Have the vehicle checked for codes as well, even if the "check engine" light is not on. These need to be ruled out first as they are very common and the simplest. Check back in once this is done. Good luck. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
