Sbristow84 Posted August 8, 2021 Report Share Posted August 8, 2021 Has anyone attempted to remove the oil pan from a 2009 3.5 V-6? My gasket is leaking and I went to change it. But I can get the pan off all the way. It is almost as I have to pull the exhaust off the block to drop the pan. Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 8, 2021 Report Share Posted August 8, 2021 Pics? Might want to clean up threads on drain plug as same time, they have a tendency to seize up. My brothers did. Its not uncommon to have to remove exhaust on some engines for oil pan removal. Maybe jack up from underneath with a motor mount removed might gain clearance. Quote Link to comment Share on other sites More sharing options...
