Mystery button
Brett
  On 8/15/2021 at 10:10 PM, Brett said:
Yes there's a wire that goes up into a larger harness and I don't know after that. As far as removing the button, that was on advice of a doge service center.
Expand
So if you unplugged it and then removed it and you knew it wasnt OEM ,and the journey still runs fine ,why ask what this plug is for as it was NOT OEM, and the dealership said to remove it, and we had to drag info out of you trying to help, Trying to not being a dick but DAM,
