agu7
I have a 2015 Journey Crossroad 3.6L with 94,000 miles, an a code P0304 cylinder 4 misfire.  After doing all things mention below, the engine runs smother and it fills with more power....however, when I start the engine or while I'm at a stop light the RPM's are between 500-600 too low. And the Scanner still reading the same code.
What I have done to correct the issue with no luck?
- I swap coils 4 and 2
- replaced all 6 coil-on-plug insulator boots with new ones
- replace spark plug #4 with new one
- cleaned all fuel injectors (I removed the injectors and cleaned them with a wire brush, and also connected a cleaning line tool with the straw to the fuel line and a carb cleaner)
- cleaned O2 sensors
Note:
At 90,000 miles (3 months ago) I replaced the oil/cooling filter housing with gaskets, replaced oil & filter, replaced all spark plugs and the pcv valve.
I can't find any air leaks...
Any recommendations? Thanks in advance
Pulling the fuel injectors and "cleaning" the nozzle tips (particularly with a wire brush) is not the best way to handle that situation. The spray pattern is done internally in each injector. IF there was that much "gunk" on the injector tips to warrant you trying that, then I'd surmise that there is an excessive amount of intake valve deposits and internally "gummed up" injectors to warrant using a can of Seafoam in the fuel tank and a good LONG drive at highway speeds. Note this is NOT an "instant fix" cure, but more cost effective than new injectors and cylinder head removal for decarbonizing.
Compression on cylinder 4 would be useful information.
When you did oil cooler housing (like a lot of us also had to do) you had upper and lower manifolds removed.
it’s a good idea to replace both sets of gaskets at same time, the old  gaskets get crushed a bit. Air leak from bad intake manifold seal can create a cylinder misfire code sometimes.
I had a similar issue on a Town and Country with the same 3.6 engine.  In my case it was a consistent cylinder #5 misfire DTC.  It would run rough at idle, but smoother at speed.    I ruled out the spark plug, coil, injector, computer, and upper cylinder head components.  The results of a compression test were acceptable.  In the end, it was ultimately a bad piston ring.  While it would make acceptable compression on that cylinder, it would not hold compression very long.  So using a simple compression tester did not show anything wrong.  It ended up being a leakdown test on that cylinder that revealed the problem.  I never skipped an oil change or any other maintenance so I'm not sure how the ring became damaged.
I hope this isn't the case for you, as that's a MAJOR repair or possibly even an engine replacement.
  • 2 years later...
Hi sorry to piggyback on your post not sure where to start a new one... I have a 2008 dodge grand caravan 3.8 l. K so first it was showing a issue with the pcm, replaced battery its fine then was leaking coolant pcm noticed a problem in cooling system. Found a Crack in hose, fixed. But prior to finding Crack I thought it was the thermostat possibly so took it off to boil it to test, it was fine - k so now the problem, I took off the spark plug wires from the ignition coil cylinders 2,4, and 6 they were in the way of the thermostat, and me being dumb started it without connecting said wires. Now I have a misfire in cylinder 4, code po304  I have changed the ignition coil, nothing. Would it be the plug or wires as they weren't connected? Or have I done something far worse? x) before changing coil which I figure was fine before I noticed no spark coming from the 4 diode. No noticeable frying of the electrical connector or fuses popped. Any advice?
