Evlmarine Posted October 2, 2021 Report Share Posted October 2, 2021 Here is a short video of the SRI I made using the secondary intake tube by cutting off the restrictive intake air diverter tubes and covering the holes with the ends of the tubes using JB Weld. You can hear the engine breath better... Quote Link to comment Share on other sites More sharing options...
Armando G Posted October 3, 2021 Report Share Posted October 3, 2021 Interesting. Do you notice an improvement on performance? Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 3, 2021 Report Share Posted October 3, 2021 so he turned his cold air feed fed in from the front grill into a hot air feed from the engine heat,, sure makes more noise ,kind of like the old days when we flipped our air filter lid upside down on on the filter housing that sure made more noise sounded good but that is all it did Summer Solstice, OhareFred and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 4, 2021 Report Share Posted October 4, 2021 Must sound cool! Quote Link to comment Share on other sites More sharing options...
John/Horace Posted October 4, 2021 Report Share Posted October 4, 2021 I hope the JB weld doesn’t crack and something gets sucked into intake. Thermal plastic welding the parts would be a better idea. There are kits you can buy with a torch and a few types of plastic welding rods, PE, abs, etc. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Evlmarine Posted June 12, 2022 Author Report Share Posted June 12, 2022 modified intake is temporary, just got the carbon fiber to make the permanent tube. the JB weld will never crack due to the heat from the engine, the pentastar V6 does not make that much heat. Locosiete 1 Quote Link to comment Share on other sites More sharing options...
Evlmarine Posted June 12, 2022 Author Report Share Posted June 12, 2022 the heat from the engine is not significant enough to hinder power or air temperature difference from the engine bay. ? Locosiete 1 Quote Link to comment Share on other sites More sharing options...
bigpapitx Posted July 24, 2022 Report Share Posted July 24, 2022 On 10/2/2021 at 1:12 PM, Evlmarine said: Here is a short video of the SRI I made using the secondary intake tube by cutting off the restrictive intake air diverter tubes and covering the holes with the ends of the tubes using JB Weld. You can hear the engine breath better... Respectfully, those helmholtz resonators aren't or can't be restrictive. They merely tune out drone from the intake. If you like the results, rock on. I went a little different approach. Locosiete 1 Quote Link to comment Share on other sites More sharing options...
