OBD2 will not work
I have  a 2009 Dodge Journey and the OBD2 plug will not work you hook a scanner to it and it says unable to read and then my boss man said change the Cigarette lighter fuse then he leaves and I go to youtube to watch videos  and they say there's a fuse box under the hood and under the glove box but there is no fuse box under the glove box but we have 2 cigarette lighters in our car How do I locate the right Fuse  and is there another fuse box I am not seeing also if the wrse case scenario happens how to put in a new OBD2
If scanner screen is coming on then usually you have actual 12 volt power and fuse is not the issue.
Is the ignition cycled to run position so full cluster lights are on, this creates link to obd2 reader for data transfer.
Is this scanner functional on other vehicles?
Fuses for most stuff are on passenger side kick plate area, behind black square plastic cover.
