None of my windows work 2016 Journey
Hello,
None of my windows will work, at first only the driver side window wouldn't work, but the other ones worked. Then the drivers side door had to be opened for all of the windows to work from the main switch and all passenger switches. Now none of the switches work and even if the door is open the windows do not work. The mechanic wants to charge me $600 to fix it, he says the motor is bad and needs to be replaced. I am not sure if all the motors are bad, or just the one in the driver side door. I bought a new driver side switch, but that did not help. The driver side window Switch makes a buzzing sound. I even checked for a broken wire, but I didn't notice any broken wires in the door. Any help would be greatly appreciated. Thanks!
  • 2 years later...
