Dubie Posted January 25, 2022 Report Share Posted January 25, 2022 New to the forum. Replaced the starter in 2010 Journey and started fine, ran smooth. After 5-10 minutes it began to have a tinny rattle in starter area. Can’t determine what that would be. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 26, 2022 Report Share Posted January 26, 2022 Crack in the Flex Plate? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 26, 2022 Report Share Posted January 26, 2022 (edited) Welcome to forum. Which engine, 2.4 or 3.6 , milage ? Did you use a torque wrench on all fasteners? Some starters have a sheet metal heat cover held with small 10 mm nuts, if they aren’t tight could cause rattle. If exhaust was removed during job, it could cause a rattle. Starter meshes with flex plate mounted to torque converter. It’s held with grub screws, if they come loose can create a rattle. Like laryl mentioned, crack can do that as well. Pretty rare thing to happen. Heat shield pic for 3.6. Edited January 26, 2022 by John/Horace Quote Link to comment Share on other sites More sharing options...
