xdm inc Posted February 9, 2022 Report Share Posted February 9, 2022 So today all of a sudden I'm driving and I see a large amount of smoke coming out from the engine so at first I gave it some oil and that wasn't the problem. then I look at coolant tank which was just recently filled is now empty so I gave it some more and then a couple blocks later I find it on the floor leaking out. All the time the fan would not kick on the radiator because my temperature gauge still tells me that it's "not overheating" it's halfway and it won't go any higher. On initial boot the gauges do move freely up and down. What do you guys think the issue might be? My first thought is maybe a faulty water pump? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 9, 2022 Report Share Posted February 9, 2022 Which engine in car, how many miles. Any recent work done on car. Water pump failure sometimes has a knocking sound or bearing noise when it fails, along with seal leak. Aluminum engines very sensitive to heat, be careful not to over heat engine. Lots of hoses and plastic cooling system parts could be cause as well. If you were topping up glycol, there was an existing leak. Quote Link to comment Share on other sites More sharing options...
xdm inc Posted February 9, 2022 Author Report Share Posted February 9, 2022 v6 3.5L 96,850 miles and no work as far as i know, just go it from the dealership 11 days ago. car fax came up clean Quote Link to comment Share on other sites More sharing options...
larryl Posted February 9, 2022 Report Share Posted February 9, 2022 Could also be your oil filter cooler housing has blown up antifreeze runs through there also Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 9, 2022 Report Share Posted February 9, 2022 On 2/9/2022 at 3:33 PM, larryl said: Could also be your oil filter cooler housing has blown up antifreeze runs through there also Expand It’s not the plastic cooler like the 3.6 that seems to have lots of issues (mainly around 2014 design change) with. The 3.5 is a stainless steel plate pack heat exchanger with a few gaskets, no plastic I believe. My brothers 3.5 went 330 k kilometres without heat exchanger issue. Pic of unit from rock. It’s timing belt engine, so water pump is often changed during belt change because it’s buried behind covers and belts. Timing belt is due for change, years and miles both call for it. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 9, 2022 Report Share Posted February 9, 2022 i think you are confusing that engine with the 3.6 that does route coolant thur the oil cooler, that said his response to adding oil but that wasnt the problem then notices coolant tank empty then refills it then it is low again after driving and sees it leaking he needs to take it to a qualified garage for a diagnostic and repair Quote Link to comment Share on other sites More sharing options...
larryl Posted February 10, 2022 Report Share Posted February 10, 2022 My bad.... 2late4u 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 10, 2022 Report Share Posted February 10, 2022 Timing belt driven water pump pics. It’s hidden behind plastic covers on front of engine. Time consuming repair. Quote Link to comment Share on other sites More sharing options...
xdm inc Posted February 11, 2022 Author Report Share Posted February 11, 2022 The dealer I brought it from fixed it up and he said it was a simple cracked coolant tube. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 11, 2022 Report Share Posted February 11, 2022 Good, great news. Thanks for follow up. Google interference engines, timing belt needs to be changed soon, if it breaks when car is running the pistons hit the valves. You aren’t over on miles, but you are on years. Unless you are sure it was changed out already. Quote Link to comment Share on other sites More sharing options...
