Location of remote entry module
Looking for the location of the keyless entry module in the 2010 DJ base. My 94 grand caravan was having parasitic draw issues and when I removed this module it fixed it. This may be the issue with the DJ also as it goes to 11.3 volts and doesnt start unless the block heater and trickle charger are on. I want to test the modules' wiring for bad ground issues as part of going over all grounds in the car. Ty
For the year model you have, try the Easy THING first. iT IS WIDELY DISCUSSED ON THE FORUM THAT THE GLOVE BOX LIGHT SWITCH GOES OUT OF ALIGNMENT AND KEEPS THE GLOVE BOX LIGHT TURNED ON.
I'm to LAZY to retype this....My big clumsy fingers hit the caps lock button.   No shouting was meant.
