Help
Brendon
I have a 2010 journey. It has a few issues I’m not really sure what they are. First is when I start my car and put in reverse it stalls. But only when it’s cold if the Engine is up to temp it does not. My second issue is sometimes when I’m driving it’s stays in 2 gear. It think it’s second. It only goes 40. To get it to stop I have to put in park and turn off. I was just wondering if anyone has an idea what the issue would be. Thank you,
Even without a light I would still check for codes. Stalling when cold could be a dirty mass air flow sensor; use the proper rated aerosol cleaner.  Even worn plugs can do that, how many miles on plugs ?
Limp mode can be lots of things, start with new oil and filter if it hasn’t been done. Usually limp mode will leave a trail of codes, but tranny codes often won’t show up with a cheap obd11 reader.
