Nosizwe Mthethwa Posted April 18, 2022 Report Share Posted April 18, 2022 I have a Dodge journey 2013, yesterday I got stuck in the mud but manage to come out. Now when I start the car everything works even changing gears but it doesn't want to move . I put it on drive, it's not woving forward even on reverse still the same thing?. Please assist what did I do wrong? Is there a button I must press ?? Quote Link to comment Share on other sites More sharing options...
tsteves5 Posted April 18, 2022 Report Share Posted April 18, 2022 Does it make any unusual noises? Can you verify that you have the All-Wheel Drive version instead of the Front Wheel Drive version? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 19, 2022 Report Share Posted April 19, 2022 You need to disable traction control when you get stuck. It allows a bit of wheel spin for getting out. You can’t spin the wheels for long periods of time without overheating transmission very quickly. Try unhooking battery for a few minutes to see remote possibility it’s just stuck in limp mode. A code reader that can access transmission codes is needed to see what parts could be damaged. Torque converter, pump, fluid body etc. It may not be the first time the car has been in the rhubarb; automatic transmissions can be fragile. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
