Wingnutt Posted May 4, 2022 Report Share Posted May 4, 2022 Need to pick the mechanics on the forum's brains.... 2015 journey sxt. Started this yesterday but was barely noticeable..only heard it when i hit the brakes. Got home called under neath it. Noticed a broken trans mount and the gaskets on the exhaust between the cats are leaking. Couldnt find the noise.... today its louder then quieter. Oil level is fine. Was recently changed at the dealer. Sometimes wont do it unless its in gear, sometimes when the fan comes on. Other times will do it while sitting on level ground. Dont believe it's a rod knock because its inconsistent. Goes and comes whenever. No CEL. Oil pressure is fine. Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 4, 2022 Report Share Posted May 4, 2022 well i would fix the trans mount and exhaust leak first before trying to fix a noise that is hard to replicate,also what kind of noise? rattle or metal clanking or whatever? Quote Link to comment Share on other sites More sharing options...
