cooling fan problems
troyhatt
2009 dodge journey RT.
Engine sometimes overheats.  Cooling fan only works on low speed, even if its running hot with the AC on.  If i unplug the coolant temp sensor then the fan will run in high speed only. Could the temp sensor be bad?  Thanks for any help.
