mjbarbee516 Posted May 24, 2022 Report Share Posted May 24, 2022 I'm not sure how to attach an audio file here but my 2010 Journey is making this insane rapid clicking noise when I put her in AC or Run. Sometimes it will continue after I put her in drive. Tonight it was the worst ever. It's driving me insane. It got horribly loud. The engine seems to run fine. There doesn't seem to be any other electrical issues. She isn't throwing codes, yet. Could it be just the ignition switch? She just had the starter replaced due to a short inside and the strap rusting out, so I know it's not that. Thanks for any insight on this. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 24, 2022 Report Share Posted May 24, 2022 It’s coming from dash ? If a brake or signal bulb burns out there is a hyper flash on most vehicles to alert you. If bulbs are out replace them, should stop clicking. Normally it’s triggered by trying to use direction signals. If no bulbs are out, Open fuse box under hood and in passenger side floor kick panel. Feel each relay for vibration to isolate which one is triggering. Quote Link to comment Share on other sites More sharing options...
