roxycharbonnet Posted May 31, 2022 Report Share Posted May 31, 2022 I hopE this is the right place, so I replaces the battery , and the flashlight didn’t come back on. I check for continuity from the prongs and it was bad , cleaned the corrosion off and that’s good , but it’s still not working, circuit board looks ok visually, anyone know how to check the board to find out if it’s bad or not? Quote Link to comment Share on other sites More sharing options...
roxycharbonnet Posted June 9, 2022 Author Report Share Posted June 9, 2022 Is a flash light an accessory? I believe it to be so. Check continuity where exactly? There’s a lot of places on the circuit board. Can u be more specific, and if this isn’t the right forum then which forum should this be in? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 9, 2022 Report Share Posted June 9, 2022 I assume you are referring to the onboard flashlight located in the luggare area? Have you measured voltage at the charging prongs? (not just continuity, actual voltage to charge the light). Did you replace the battery with the correct, rechargable type? Did it ever work? Honestly, I didn't know anyone actually used it. Quote Link to comment Share on other sites More sharing options...
roxycharbonnet Posted June 9, 2022 Author Report Share Posted June 9, 2022 I’m new here. Which forums do u think I’d have better lucK ? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 9, 2022 Report Share Posted June 9, 2022 On 5/31/2022 at 4:36 PM, roxycharbonnet said: I hopE this is the right place, so I replaces the battery , and the flashlight didn’t come back on. I check for continuity from the prongs and it was bad , cleaned the corrosion off and that’s good , but it’s still not working, circuit board looks ok visually, anyone know how to check the board to find out if it’s bad or not? are you talking about the charger port not testing good or the flashlight itself not test good either way check for the fuse to see if its blown, and also check the flashlight bulb as well to see if its good or any power getting to it, if all else fails buy a replacement after all its over 12 yrs old , e bay or oem light replacement ,,,,,,or go to harbor freight and buy a led one that will be better this is the one i have and it is great also it rechargeable as well.... BRAUN 390 Lumen Magnetic Slim Bar Folding Work Light (8260) $2999 . jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 9, 2022 Report Share Posted June 9, 2022 (edited) 46 minutes ago, Locosiete said: Honestly no idea what forums out there could help. Personally i would just replace with a new flashlight but that is just me. You had asked "are you sure this is the correct forum?". Were you referring to the actual "Dodge Journey" forum, or maybe referring to another forum out there, as in a "Dodge Journey Flashlight" forum, or just a section within this forum? Edited June 9, 2022 by jkeaton Quote Link to comment Share on other sites More sharing options...
