2009 dodge journey 3.5 awd trasfer case help with locating part
qwizzy
Ok, so about a month ago i posted about the issue of my trucks trasfer case & today since its been parked for about a month now. Ive decided to dig deeper into removing the output shaft inside the trasfer case.  I dont know if this is a easy fix or hard but, can someone tell me if this part can be replaced? The bearings are shot so i either want to buy this part completely new or used or if you know if i can just replace the bearings
There are several bearings on the other output shafts that may have major wear from the bad oil.
Just rebuilding the shaft in the pic might only buy you a few months.
A transmission shop might be able to rebuild the bad unit. But normally the cost would be a lot higher than a good used unit.
Hopefully  there will be other opinions.
