Sylvain Posted June 14, 2022 Report Share Posted June 14, 2022 Hi, My Dodge journey 2012 2.4L is starting wipers, dashboard lights are flashing, chime starting to "ping" non stop, all this while driving. Vehicule doesn't turn or shut OFF by itself while doing this problem BUT if I shut it OFF, impossible to restart it before few hours... If I try to restart it, it starts all accessories at same time without starting... Impossible tu turn OFF any accessories involved... It looks like after 12 hours it "reset" a module than is ok to restart but "check engine" light turns ON for few days then dissapear until next episode of problem... My garage is thinking about part #68164872AC. Can you please let me know if I'm the only one having this problem or it is common? Thanks, Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 14, 2022 Report Share Posted June 14, 2022 before throwing $$$ better have it checked out to see if that is the problem first,kind of expensive. have heard some readers say the power distribution box has caused them problems with corrosion under there where the connectors are,good luck most dodge dealerships charge around 100 to 150 to check something like this out they would be the best place to have it checked but also probally the most expensive as well.........Good luck Quote Link to comment Share on other sites More sharing options...
mamallama Posted May 7, 2024 Report Share Posted May 7, 2024 Hi there. I know this post is 2 years old, but I was wondering if you ever determined the issue? I currently have a 2012 Dodge Journey RT. About 2 months ago, I had the first, shall I say "event". While driving one night, the wipers came on by themselves, the dash lights went out, my dash warning lights came on, and I had a NO BUS message where my odometer reading would typically be. Went home, put the battery charger on it, (charge after each event, and battery is typically down to about 50% at the time). Took it to a local garage, paid for a diagnostic, which said TIPM was the issue. We have replaced the TIPM and it is doing it again. We are at a loss, and cannot afford to keep taking it for "diagnostics", only to find out that the answer did not fix the issue. Thank you! Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 7, 2024 Report Share Posted May 7, 2024 (edited) as you said a 2 yr old post with no follow up from the org poster who only posted one time, this doesn't help other people needing help as well....feed back is very important on the solutions to their problems Edited May 7, 2024 by 2late4u jkeaton 1 Quote Link to comment Share on other sites More sharing options...
chader100 Posted August 2, 2024 Report Share Posted August 2, 2024 Hello, I am having the same issue with my 2013 Journey and it's becoming rather annoying to get stuck somewhere for longer than I wanted to be or even drive with the windshield wipers going. Paid for something to be done which did not work. Was hoping someone had the answer and approximate cost to fix. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 4, 2024 Report Share Posted August 4, 2024 The answer is really trouble shooting to narrow it down to one problem or part. Often it’s grounds and not a power supply issue. So cleaning up as many frame grounds as possible is always a good starting point, takes a bit of time. It could even be a module like the BCM that controls multiple grounds for the wire harness. And can be a vehicle option specific part. Electrical speciality shops are often better at this than general maint mechanical places. Dealers sometimes have a person who specializes at it. Wiring schematics and knowing how to read them…is usually required. Checking for ecm codes is another important step. Free advice worth everything you pay for it. 2late4u and larryl 2 Quote Link to comment Share on other sites More sharing options...
larryl Posted August 4, 2024 Report Share Posted August 4, 2024 And never come back to update........... Quote Link to comment Share on other sites More sharing options...
Dean H Posted August 7, 2024 Report Share Posted August 7, 2024 (edited) For Journey electrical issues start here. The ground system is a weak point. Doing a ground upgrade is cheap and simple to do. https://www.dodgejourneyforum.com/topic/18374-electrical-system-fyi-ground-system/ Edited August 7, 2024 by Dean H Quote Link to comment Share on other sites More sharing options...
