JustDodge Posted June 22, 2022 Report Share Posted June 22, 2022 I have a 2012 Journey with the 3.6L. I seem to be experiencing this issue where it’s like a loss in power. When I need or demand power, it’s like the transmission will send the car into its higher gear and rev the engine out. Even with it doing that it still feels sluggish. My mom has a 17 with 3.6 but her just has power on tap. I have to bury my foot and let the engine rev out to get power that’s often found in the lower power and of the 3.6 Journey. Not sure if the trans has been tuned over the years or if it’s because it has almost 150k miles. Does anyone have and clue or understanding what this may be??? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 22, 2022 Report Share Posted June 22, 2022 clean off your oil dipstick and insert it into the trans fill hole to see the level and color of your trans fluid ( should be pink or red if dark or burnt looking it will be brownish looking), youtube can give you the measurements on how to mark the oil dipstick to check the trans fluid level, but yes it sounds like the trans is slipping, you are 50 k over the recommended trans service and probally the same on the sparkplugs ( 100k) which could be part of your problem along with the coolant serace change (120 k) as well Quote Link to comment Share on other sites More sharing options...
tsteves5 Posted June 23, 2022 Report Share Posted June 23, 2022 Agreed, it does sound like the trans is slipping. You MIGHT get lucky and a fluid and filter change could remedy the issue if the trans isn't too badly damaged. Quote Link to comment Share on other sites More sharing options...
