Craig Posted September 4, 2022 Report Share Posted September 4, 2022 This car is not my favorite thing right now. P2504 logged code. I assumed regulator in the alternator was shot so a new alternator went in. Still getting 16v at idle. 14 with engine off. The voltage actually increases when turned off! New battery, new voltage sensor on the negative terminal. Radio shuts off sometimes. Battery saver mode will show up now and then. Sometimes it will fully discharge over a 4-5 hour period, this happened twice in thr last 10 days. The plastic around the under hood jumper terminal was melting and smoking today. Anyone able to help.? Thanks Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 6, 2022 Report Share Posted September 6, 2022 welcome to the group, sorry to hear about your problem, due to the holiday most are not reading the blog i am sure someone will chime in soon,,I hate to say there has been a lot of discussions on non starting problems,when you find your solution please report back on what you had to do to fix it for others that might have this happen to them Quote Link to comment Share on other sites More sharing options...
