jas Posted September 8, 2022 Report Share Posted September 8, 2022 Have 2017 Dodge Journey Crossroad traction control light on scanner error code C0051 22 : Steering Wheel Position Sensor - Signal Amplitude > Maximum when measure live data SAS degrees get -365 degrees when steering wheel in straight tire position If turn wheel right gets more negative to -700 If turn wheel left gets more positive -100 Numbers are approximate it seems to work but straight wheel I think should be 0 degrees The vehicle had collided with a cement wall and front had to be repaired All was fine for a couple of weeks but now TCS light comes on I have seen YouTube videos with same problem and fixed with SAS reset/recalibrate I have ordered a iLink400Full with Chrysler Dodge Jeep software which is supposed to be able to reset a 2017 Journey but have been waiting for some time I do not know if they did a front wheel alignment and forget to reset the SAS Has anyone had similar issues I tried all forms of self-calibration where I turn steering wheel left lock to right lock and vice versa and then center steering wheel , shut engine off and then on again. Did this 1, 2 and 3 times and then drove vehicle but did not work when I cleared the code and measured live data again scanner showed: Steering angle: -365 degrees for straight wheels (cantered steering wheel) Steering angle status : valid I found the status as valid to be strange when I turned steering wheel right the TCS light came on. The scanner I used said my Journey did not support SAS function. If this is the case why did the iLink400Full say it can calibrate a 2017 Dodge Journey Steering Angle Sensor Can anyone help and advise me Thanks Quote Link to comment Share on other sites More sharing options...
jas Posted September 21, 2022 Author Report Share Posted September 21, 2022 Got the iLink400 and reset SAS but had no affect Took it to Dodge dealer who indicated clock spring had been damaged. They indicated that the steering rack had been repaired and felt it had been damaged at time of wheel repair. They have ordered new clock spring. Will advise final result 2late4u 1 Quote Link to comment Share on other sites More sharing options...
