Spifficult Posted September 14, 2022 Report Share Posted September 14, 2022 I have a 2019 journey that I've had barely a year. Most of the summer it was fine, but the past few weeks the climate control will turn on by itself. A lot of the times, I push OFF and it comes right back on. I believe I have the manual dual zone. Today it was 66°, not humid, and it did it about 8 times in a row. Only while driving,not while parked or sitting still. Of course the manufacturer warranty ended last month. Quote Link to comment Share on other sites More sharing options...
CBD Posted September 14, 2022 Report Share Posted September 14, 2022 Do you have controls for the rear vents in the head liner? If so, you have to make sure that is off as well. If that is on it will keep turning the front controls on. Quote Link to comment Share on other sites More sharing options...
tsteves5 Posted September 14, 2022 Report Share Posted September 14, 2022 6 hours ago, CBD said: Do you have controls for the rear vents in the head liner? If so, you have to make sure that is off as well. If that is on it will keep turning the front controls on. Mine had this issue even with the rear (headliner) controls turned off and locked. I replaced the rear controls with a junkyard unit and it fixed the issue. Quote Link to comment Share on other sites More sharing options...
Spifficult Posted September 14, 2022 Author Report Share Posted September 14, 2022 7 hours ago, CBD said: Do you have controls for the rear vents in the head liner? If so, you have to make sure that is off as well. If that is on it will keep turning the front controls on. Shortly after I posted this my car made me a liar. I was sitting in the parking lot with my car running and it turned itself on. Shut the back off with the back headliner control and still did it again. I'll see what happens on my next drive that's longer than 5 minutes. Quote Link to comment Share on other sites More sharing options...
CBD Posted September 15, 2022 Report Share Posted September 15, 2022 Mine is a little finicky. With the AC on (both front and back) shut the back off first, then the front. Make sure the back is at off. On mine, there is a "dot" for off and then it can go one more click to "AUTO". If it is on "AUTO", it will still come back on. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Spifficult Posted September 15, 2022 Author Report Share Posted September 15, 2022 5 hours ago, CBD said: Mine is a little finicky. With the AC on (both front and back) shut the back off first, then the front. Make sure the back is at off. On mine, there is a "dot" for off and then it can go one more click to "AUTO". If it is on "AUTO", it will still come back on. Thank you, I will do this. I didn't even look when I reached back to turn it off so maybe I accidentally put it on auto. I'm not sure if there's an auto option, but I'll make sure to check now. Quote Link to comment Share on other sites More sharing options...
Laura Johnson Posted October 8 Report Share Posted October 8 On 9/14/2022 at 8:37 AM, Spifficult said: I have a 2019 journey that I've had barely a year. Most of the summer it was fine, but the past few weeks the climate control will turn on by itself. A lot of the times, I push OFF and it comes right back on. I believe I have the manual dual zone. Today it was 66°, not humid, and it did it about 8 times in a row. Only while driving,not while parked or sitting still. Of course the manufacturer warranty ended last month. My boyfriend fixed this , the wires that go to fuse box . My ac still comes on itself tho but all other issues have stopped like battery light , one window not working , the only think I have not figured out is the ac come on in the front by itself, if I cut off it comes back on Quote Link to comment Share on other sites More sharing options...
