David.o Posted September 16, 2022 Report Share Posted September 16, 2022 ok so not sure where to even start but this is what im dealing with my obd2 sensor says my thermostat is stuck open and my radiator has a crack in it with im going to replace both but my radiator fan is not coming....however if i take out the 2 fan relays and the fan fuse from under the hood crank the engine and then reinstall the relays and the fuze the radiator fan comes on and does not turn back off until you turn the engine off , if i turn on the ac sometimes the fan come on and off and sometimes it comes on and stays on and sometimes not at all i was thinking maybe my temp control sensor but im getting what i assume to be a good temp readin on my dash any help would be greatly appreciated . Quote Link to comment Share on other sites More sharing options...
David.o Posted September 16, 2022 Author Report Share Posted September 16, 2022 ment to say obd2 reader Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 16, 2022 Report Share Posted September 16, 2022 WHICH ENGINE? the 2.4 or the 3.6? Quote Link to comment Share on other sites More sharing options...
David.o Posted September 16, 2022 Author Report Share Posted September 16, 2022 3.6 sorry forgot to add that Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 16, 2022 Report Share Posted September 16, 2022 (edited) You posted of a cracked radiator(have to be loosing coolant) and showing low engine temp(you say T-stat stuck open). REPLACE THOSE ITEMS and be sure to purge air entrapment out on refilling the coolant. THEN see what the fans do after a GENTLE road test! NOTE: this engines cooling system LOVES to entrap air and causes all kinds of "goofy" symptoms. Edited September 16, 2022 by 5rebel9 2late4u 1 Quote Link to comment Share on other sites More sharing options...
