8 hours ago, jkeaton said:
Check the driver side door switch.
Neither driverside doors turn on the dome lights, so may be in the wiring. I don't think that both switches would go bad at the same time. I hope it's wiring, it's easier to fix than the cost of 2 door latches.
@Yogitech1, looks like you just bought this car and have a lot of miscellaneous issues. Did you get the car checked before you bought it? Did you do a good check yourself before buying? Did you get a "good" deal on it? Do you have any maintenance records for the car? It is a 12+ year old car, so I assume there are going to be a lot of 'age' issues coming up with the car.
