Yogitech1 Posted October 7, 2022 Report Share Posted October 7, 2022 How can I turn down idle speed with no vacuum leaks? I don't want to burn up transmission or the breaks. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 7, 2022 Report Share Posted October 7, 2022 How high is the idle? Perhaps an issue with the TPS if there are no vacuum leaks. Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted October 7, 2022 Author Report Share Posted October 7, 2022 8 hours ago, jkeaton said: How high is the idle? Perhaps an issue with the TPS if there are no vacuum leaks. It idles at 1500 rpm. I put it neutral when stopping as to not burn up the transmission. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted October 8, 2022 Report Share Posted October 8, 2022 Scan for codes first. Like Keaton is saying throttle position sensor could cause this. It’s drive by wire so several sensors are in play like gas pedal potentiometer as well. Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted October 14, 2022 Author Report Share Posted October 14, 2022 On 10/7/2022 at 9:23 PM, John/Horace said: Scan for codes first. Like Keaton is saying throttle position sensor could cause this. It’s drive by wire so several sensors are in play like gas pedal potentiometer as well. I found 3 or 4 codes all pointing to the ABS module not communicating with the ECM. Nothing about throttle body or TPS. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted October 15, 2022 Report Share Posted October 15, 2022 Seems weird. ABS shouldn’t affect engine idle. Something seems to be giving extra air or fuel. What brand of scanner, some are better than others. Quote Link to comment Share on other sites More sharing options...
Armando G Posted October 15, 2022 Report Share Posted October 15, 2022 Out of curiosity, what codes did you get? Have you looked at any of the basics? Something as simple as needing a new air filter could cause the idle RPM to rise. I could give you a list of suggestions, but prefer to start with what have you already done? Anything at this point would be a shot in the dark. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted November 8, 2022 Author Report Share Posted November 8, 2022 On 10/15/2022 at 2:35 PM, Armando G said: Out of curiosity, what codes did you get? Have you looked at any of the basics? Something as simple as needing a new air filter could cause the idle RPM to rise. I could give you a list of suggestions, but prefer to start with what have you already done? Anything at this point would be a shot in the dark. I replaced the ABS module but, didn't seem to fix the issue. However, driving around Sunday evening I looked down, the speedometer, odometer we're working and the engine light went out. It fixed itself somehow. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted November 8, 2022 Report Share Posted November 8, 2022 Try cleaning up the main body grounds. Strut towers under hood have several and they get messy. Issue may come back again. Quote Link to comment Share on other sites More sharing options...
