Help required ETC warning light on dash
Hello i have had this warning light appear on my dash , and had a loss of power , does this mean my throttle body needs replacing ??, also  once i finally got the car home there seemed to be a burning smell coming from the car , can anyone help please ??my vehicle is a dodge journey 2013
have you had it scanned for any codes? that will lead you in the right direction without throwing parts at it..... a solid warning light means you have a problem but still okay to drive it to get it fixed, a flashing warning light means to shut it off and have it towed or damage will happen to your journey...you might be able to clean it first before replacing it depends on your situation on $$ and parts available check out you tube for vidios on how to clean or replace such part but id get it scanned first for codes
Edited by 2late4u
  • 2 years later...
