larryl Posted December 6, 2022 Report Share Posted December 6, 2022 So I was able to find a TPM Module on Ebay (used) for $60 as the dealer here told me $380 but none available I installed it today after removing the fuse on the passenger side panel and with the new one installed and the fuse put in the readings all appeared and no more warning lights. Here is a picture of the module John/Horace 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 7, 2022 Report Share Posted December 7, 2022 (edited) Another option. Canadian shipping can add up. Where was it mounted in car.? I have one non communicating sensor right now. Will have to trouble shoot. https://www.moparpartscanada.ca/oem-parts/mopar-control-module-56029542ad https://parts.motorcitychrysler.ca/p/49458852/56029542AD.html Edited December 7, 2022 by John/Horace Quote Link to comment Share on other sites More sharing options...
larryl Posted December 7, 2022 Report Share Posted December 7, 2022 (edited) It's underneath the left rear wheel shield mounted on the front corner 2 10mm bolts hold it on . Pretty easy with the wheel removed I switched wheels around to make sure it wasn't the sensor Edited December 7, 2022 by larryl spelling John/Horace 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted December 7, 2022 Report Share Posted December 7, 2022 5 hours ago, John/Horace said: Another option. Canadian shipping can add up. Where was it mounted in car.? I have one non communicating sensor right now. Will have to trouble shoot. John, did you first TRY swapping that tire to another position to rule out a bad tire sensor? IF it move to the new location and not reading, it is then a bad tire sensor and most likely not the receiver module. Many have posted of a wheel not reading but never replying back of doing this as part of troubleshooting before parts cannoning in possibly UNNEEDED parts. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 7, 2022 Report Share Posted December 7, 2022 No I haven’t yet. Light came on two weeks ago and was due for winter no sensor tires to go on. But on a warm day I will throw the offending summer tire with flaky sensor back on in different spot and see what happens. Have a bead breaker, so even if I have to pull through a new sensor I’m not worried. Its nice on dodge with winter no sensor tires. System shuts itself off more or less with out flashing disco warning lights every time car started. Other car manufacturers could learn from that. Quote Link to comment Share on other sites More sharing options...
