Dodge Journey 2015 problem
2 hours ago, Sandy said:
It’s not on a hill, also the traction and abs lights are on
need to have someone scan it with a good scanner for codes,,,traction and abs lights can mean a lot of different things from a wheel speed sensor to a bad abs module as that is what i an waiting on for the dealership to get the module in stock come jan1
@Sandy a hummm is usually your starter not engaging and just spinning, creating a hum. If you have other symptoms, get your battery tested to make sure you have enough juice. Also make sure the battery is fully grounded and that the connection is clean. From there you can have the starter tested.
advance auto was testing my battery one time on my 2001 truck  and also the alt and then he printed out that my starter was reading low on current but he said dont worry about till it goes out that was around 10 yrs ago and my stepson is still driving it with no starter problems...LOL
