sunstealth Posted October 13, 2022 Report Share Posted October 13, 2022 Anyone knows which pins I need to install wire in at the oem connector ? I swapped to a 8.4 which has reverse camera and NAV capability. I previously had an Android unit so I have an aftermarket reverse camera. Just need to know where to hook up the wiring at the factory 8.4 plug. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted October 22, 2022 Report Share Posted October 22, 2022 If you download the installation manual for the OEM backup camera for the 2011-2013 models it has the pinout, because the vehicle wasn't prewired. This link will get you that manual. Good luck: https://s3.amazonaws.com/rp-part-images/assets/98fe84911b8f2acb751e9a23cfbbfd97.PDF Quote Link to comment Share on other sites More sharing options...
