Samuelsteven Posted October 18, 2022 Report Share Posted October 18, 2022 I purchased a used 2009 year model from an auction the other day. The vehicle was in pretty good condition but would not start because of a breathelizer machine that was installed. Once I removed that from the vehicle, it started right up and I reversed it off of the tow dolly I picked it up on. The brakes sounded horrible and had no resistance at all. Here's where all the craziness started. The truck had a bunch of dash lights on, so I scanned it with my autel and the one o saw about 3 times in 3 different sections, was "lost communication with ABS module". There were a few other losses of communication. I noticed a fluid that had created a small puddle at the front driver tire. I got under the truck and saw fluid leaking from the caliper, which I figured is why there was no brake pressure. A few of the rotors looked and felt horrible, so I decided to order a new set of rotors and brake pads. Once I started removing the front caliper that was leaking, I discovered it was kissing an entire outer pad, which caused the piston to come out more than it was supposed to and separated from its seal, and why it was leaking. Replaced the seal, rotor and brake pad and went on to the next. On the rear drivers side, I had to buy a new caliper bracket, as the original had a frozen guide pin, I've never seen one like it. They're supposed to move in and out freely so the pad can travel in and out, well it was stuck completely. Once I replaced them all, I refilled the resovoir and bled the lines. I was hoping it being low on fluid is what was causing the loss of communication, but no. I have attached the codes as photos. The other problems I have are, the driver side vents aren't getting cold with AC, but passenger side is. No blower motor working in rear, and have that code. The fold down monitor has no power. before I start tearing down the rear to get to the blower motor, I'd like to know if the loss of communication to that, the ABS module, tv screen, hands free may be the issue with the blower too. How would I go about pinpointing the can-bus problem? Any help is appreciated Quote Link to comment Share on other sites More sharing options...
Samuelsteven Posted October 18, 2022 Author Report Share Posted October 18, 2022 Couldn't fit all in the original post Quote Link to comment Share on other sites More sharing options...
Samuelsteven Posted October 18, 2022 Author Report Share Posted October 18, 2022 Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 18, 2022 Report Share Posted October 18, 2022 sounds like you got a deal on a journey with a lot of problems,as far as the ac that is probally a blend door actuator problem check out youtube for more info on thoes i believe there are 3 of them drivers passenger and one in the middle...as far as the rest for others to comment on...good luck and welcome to the group Samuelsteven 1 Quote Link to comment Share on other sites More sharing options...
