CrisA Posted November 9, 2022 Report Share Posted November 9, 2022 Morning I was trying to see if anyone could help me with the problem in having with my 09 dodge journey sxt Okay so my problem is that sometimes when I try to start my car it won’t start when turning the key like all interior lights come on and dash but the car won’t turn on ( there’s no clicking when turning the key) so the thing I have to do it wait about 5 min and then try it again then the car turns on after that I could go 1-2 weeks with no problem until it starts doing it again it ( just won’t turn on even after turning the key 2-3 times , I always have to wait 5-10 min to try it again so it starts. The alternator is bran new and so it the battery so I don’t know what could be my problem if someone could help. ( I have also already added a second ground from the battery to my cars body and the battery terminals are all tight ) Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 9, 2022 Report Share Posted November 9, 2022 have you tried putting it into neutral and then try starting it,also could be a intermittent key switch problem,so many different possibilities...good luck larryl and Armando G 2 Quote Link to comment Share on other sites More sharing options...
larryl Posted November 9, 2022 Report Share Posted November 9, 2022 Neutral back to Park always worked for me... Quote Link to comment Share on other sites More sharing options...
luzmina Posted November 10, 2022 Report Share Posted November 10, 2022 Swap the starter relay in the under hood fuse box with other one, they are few of same type there or just put a new one. Quote Link to comment Share on other sites More sharing options...
Armando G Posted November 11, 2022 Report Share Posted November 11, 2022 (edited) Side note... remove the 2nd ground and check that the main ground isn't only tight, but making a good, clean connection at the opposite end - preferably metal to metal, not metal to paint. Clean out that connection as well as you can and reconnect. Just had to do that with my Ford that was having a very similar issue. Edited November 11, 2022 by Armando G John/Horace and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 11, 2022 Report Share Posted November 11, 2022 possibility your TPIM is acting up Quote Link to comment Share on other sites More sharing options...
