kmbkuba Posted December 8, 2022 Report Share Posted December 8, 2022 The 2013 Dodge Journey only has a continuous wiper mode. In intermittent mode, they turn on once per lever movement on each level and stop working. They stop in a good resting position. I already replaced the relays. Where is the intermittent clock? I replaced it with another (unfortunately also used) and the symptom is the same. The signal comes from it because the wipers perform one cycle ... Can the multi function switch be programmed somehow? Translated by Google... Quote Link to comment Share on other sites More sharing options...
Olly Posted December 7, 2024 Report Share Posted December 7, 2024 Hi kmbkuba, Have you solved intermittent mode problem? I've got exactly the same problem on my Dodge Jorney sibling Fiat Freemont 2013 recently and still try to figure out which module initiates the next periodical wipes. All relays and fuses are ok, body comp. hard reset does not help. Quote Link to comment Share on other sites More sharing options...
