water leak
gm61
I have a 2017 Journey with a water leak at the rear cargo  area. I checked the roof rails and antenna, all good no water coming in from there, took it to Dodge and they could not help me resolve this. the water drips down from the left side rear trin piece where it meets the roof liner. Is anyone else having this problem?
i would check all the seams going around the lift gate area,,also check your rear wiper window sprayer to see if it is spraying good you might have a leak in the plastic line that feeds it from the washer reservoir  under the hood? do you have a sun roof window? how bad is it dripping bad or just slight wetness? i believe the washer line is your problem
hello 2late4u, thanks for the reply. i will check the washer line to be sure but I think the seams around the lift gate opening is where the problem is. when it rains there is a lot of water coming in so I am thinking that is where to trouble is.
Expand
good luck ...My experiences with water leaks on cars and roofs of houses is the leak IS NEVER where you think it is.....LOL  one thing you could do is plug the plastic washer hose under the hood to see if it stops leaking back there,,thoes plastic washer lines are a piece of crap and could have froze and that can be the cause
Edited by 2late4u
  • 1 year later...
I’m having the same problem, it seems to be the seams on top of the lift gate .
it seems like the seam sealer cracked allowing water to find the way inside, I just put some adhesive sealant hopefully I fixed the problem
