wpginterceptor Posted January 20, 2023 Report Share Posted January 20, 2023 (edited) ok so car was driving and stalled out. I came to a stock and it sarted right up, with check engine light!.. drove it home about 20 min drive, stalled a couple more times on way.. Once home I checkd for codes and it gives me a P0335 which is CRANKSHAFT POSITION SENSOR! these hard to get at on these cars? PS: car runs great til it stalls out, then sometimes wouldnt start would just crank.. wait a min or 2 and it starts right up runs great til it stalls again few mins later! but made it home Edited January 20, 2023 by wpginterceptor Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 20, 2023 Report Share Posted January 20, 2023 which eng? Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted January 20, 2023 Author Report Share Posted January 20, 2023 2.4.. i found it, its on back side.. Ill change it tomoro Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 20, 2023 Report Share Posted January 20, 2023 for what it worth they say to use a oem mopar part, up to you....report back on what you do and how it turns out? John/Horace 1 Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted January 20, 2023 Author Report Share Posted January 20, 2023 (edited) oh yes I dont mess with sensors.. part # 05033307AC is the Dodge Sensor Part number.. was an ez swap! drove it around all afternoon and no more stalling out. Edited January 20, 2023 by wpginterceptor 2late4u and larryl 2 Quote Link to comment Share on other sites More sharing options...
IvanG57 Posted June 10, 2023 Report Share Posted June 10, 2023 After replacing the sensor, do you have to clear the code or recalibrate the sensor with any diagnostic tools? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 10, 2023 Report Share Posted June 10, 2023 no Quote Link to comment Share on other sites More sharing options...
IvanG57 Posted June 10, 2023 Report Share Posted June 10, 2023 Thanks. I replaced the part. I bought the part from Car quest. The Journey started right up and was running good for a bit. When I took it for a test drive I noticed after a bit the rpms started to fluctuate than it would driver normal again. The check engine light is now gone. Any suggestions what this could be now? The part I got wasn't an OEM, could that be the problem? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 11, 2023 Report Share Posted June 11, 2023 3 hours ago, IvanG57 said: Thanks. I replaced the part. I bought the part from Car quest. The Journey started right up and was running good for a bit. When I took it for a test drive I noticed after a bit the rpms started to fluctuate than it would driver normal again. The check engine light is now gone. Any suggestions what this could be now? The part I got wasn't an OEM, could that be the problem? probally ,all the advise that has been given on this site is to use an OEM part Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted June 11, 2023 Report Share Posted June 11, 2023 Prior experience, on other domestic brands, has convinced me that, when it comes to sensors, OEM is the only way. Eliminates the trial and error. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 13, 2023 Report Share Posted June 13, 2023 (edited) Could unplug battery for an hour, reseat sensor plug again,. On slim chance it does something. Scan for codes again. Edited June 13, 2023 by John/Horace 2late4u 1 Quote Link to comment Share on other sites More sharing options...
