Walkingant Posted February 10, 2023 Report Share Posted February 10, 2023 2015 dodge journey SXT AWD 6 --- My climate control shows the following: Climate control will NOT turn off --Push the off button it lights up until I remove my finger. Rear climate control does the same--can't turn off A/C doesn't come on--Push the button it lights up until I remove my finger Max A/C doesn't come on--Push the button it lights up until I remove my finger Front defrost--I push the bottom, the blower comes on full force, air comes out at windshield. Selector switch--defrost, feet, combo setting work--air comes out as designed--no heat Fan blower works--both front and rear, I can turn it up and down, but not off. A/C clutch always engaged--perhaps because I can't turn climate control off --? Rear Defrost button and on touch screen continuously flashes. (this signifies blend doors not calibrating?) humming noise even when engine off from under dash?? no heat --pipe into and out of heater core is hot. Manual control knob, its not automatic, control below 4.3 touch screen what works on touch screen: blower/fan speed Radio CD both heat temp controls appear to work air direction --defrost, feet- combo--works Any ideas? Body control module? the a/c heater control module behind touch screen was replaced.--no change. Blend door actuator bad? no clicking sounds. I understand no scanners except dealer can identify blend doors--climate control problems-- I have dealer appointment in a week... Thanks for any input. Quote Link to comment Share on other sites More sharing options...
Walkingant Posted February 16, 2023 Author Report Share Posted February 16, 2023 Update: Error in posting, actually the blend door for defrost/floor/mid level--didn't work. Found out aftermarket blend doors installed---couldn't be programmed? OEM being installed... Thanks all....for now. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Sherry Posted March 1, 2024 Report Share Posted March 1, 2024 I have an 2015 Dodge Journey my heat doesn’t cut off. The lights want come on with the radio or the heater and ac. I can’t cut it off the heat stays on. I had an new battery put in. It was working up to that point no problems. The touchscreen doesn’t light up at all. The radio works but I can’t see how to change it. Unless I use my settings with the steering wheel. Could someone please let me know what it could be? Thank you so much Quote Link to comment Share on other sites More sharing options...
