Alex Tasso Posted February 27, 2023 Report Share Posted February 27, 2023 2014 Journey SXT with 117k miles dies when put in reverse or drive. Starts up no problem, engine runs while in park. No smell, only sound is a repetitive soft clicking noise from the engine compartment. Not sure if it’s the transmission or an intake port or egr valve (though I just had it smogged and it was fine) Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 27, 2023 Report Share Posted February 27, 2023 So, it is not drivable at all? Did this just suddenly happen? Have you scanned for codes? Quote Link to comment Share on other sites More sharing options...
Alex Tasso Posted February 27, 2023 Author Report Share Posted February 27, 2023 (edited) It starts up and idles in Park just fine. It is not driveable. When the car is shifted into either Reverse or Drive, it dies. I had it towed to my girls house so her mechanic can look at it, but the tow truck driver thinks it might be the throttle body sensor being gunked up or dirty. Yes, it happened suddenly. When it happened, I was stopped at a red light. Then the car lurched forward slightly and the engine shut off. All the electrical components and A/C still work as well. Edited February 27, 2023 by Alex Tasso Quote Link to comment Share on other sites More sharing options...
tsteves5 Posted February 27, 2023 Report Share Posted February 27, 2023 It could be that the transmission's torque converter lockup solenoid is stuck. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 27, 2023 Report Share Posted February 27, 2023 It will need to be hooked to a scanner for a diagnostics. Too many variables to guess over the internet. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Alex Tasso Posted February 27, 2023 Author Report Share Posted February 27, 2023 2 hours ago, jkeaton said: It will need to be hooked to a scanner for a diagnostics. Too many variables to guess over the internet. I hooked an OBD-II to it and it gave me this code: Quote Link to comment Share on other sites More sharing options...
larryl Posted February 27, 2023 Report Share Posted February 27, 2023 Low Fluid .clogged filter....could be several things has the fluid and filter ever been changed? Quote Link to comment Share on other sites More sharing options...
Alex Tasso Posted February 28, 2023 Author Report Share Posted February 28, 2023 2 hours ago, larryl said: Low Fluid .clogged filter....could be several things has the fluid and filter ever been changed? Just bought it from a private seller about three weeks ago. The thing ran just fine. Took it to jiffy Lube who did all the fluids on it right after I got it. Carfax showed service on them a few years earlier Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 28, 2023 Report Share Posted February 28, 2023 Jiffy lube did your transmission fluid? Did they flush it? larryl 1 Quote Link to comment Share on other sites More sharing options...
Alex Tasso Posted February 28, 2023 Author Report Share Posted February 28, 2023 5 minutes ago, jkeaton said: Jiffy lube did your transmission fluid? Did they flush it? It didn’t need to be flushed, they said. It was still in good condition. No debris, good coloring. Quote Link to comment Share on other sites More sharing options...
larryl Posted February 28, 2023 Report Share Posted February 28, 2023 Tranny fluid so be drained not flushed it can cause a lot of problems When it's drained the filter gets changed also flushing doesn't help a clogged filter. Jiffy Lube shouldn't be messing with a transmission just saying... Good luck jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 1, 2023 Report Share Posted March 1, 2023 So the problem started after jiffy lube worked on it? If they didn't flush it, what did they do? Quote Link to comment Share on other sites More sharing options...
