Fayçal Posted March 7, 2023 Report Share Posted March 7, 2023 Bonjour, j au recenment un Problème de détection Keyless enter n go de la porte conducteur, la porte passager marche bien, en plus message sur mon tebleau de bord entret système teledeverr. Des suggestions svp Merci Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 7, 2023 Report Share Posted March 7, 2023 Greetings! Most likely cause is broken wire in the drivers door handle. There are a number of youtube videos on how to remove the outer door handle. It's a replace with new handle fix OR if you are handy with small wire soldering and repair you could fix the wire{s, there are 2} Had the same happen on our 2011 model DJ Good Luck and report back how it goes larryl 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 8, 2023 Report Share Posted March 8, 2023 18 hours ago, Fayçal said: Bonjour, j au recenment un Problème de détection Keyless enter n go de la porte conducteur, la porte passager marche bien, en plus message sur mon tebleau de bord entret système teledeverr. Des suggestions svp Merci Please post in English so the rest of us can understand you.... Quote Link to comment Share on other sites More sharing options...
Appalachian Journey Posted March 9, 2023 Report Share Posted March 9, 2023 S'il s'agit d'un fil endommagé ou cassé, envisagez de remplacer l'ensemble du fil. Le mien avait un mauvais fil d'interrupteur de fenêtre. Intermittent pendant un peu puis perte totale de fonction. Quote Link to comment Share on other sites More sharing options...
Fayçal Posted March 9, 2023 Author Report Share Posted March 9, 2023 Hey all, In the last weeks the keyless entry on my drivers side door stopped working. This feature usually unlocks my door when I place my hand in the door handle and locks it when I press the button on the handle. This is the only feature that has stopped working; the actual key FOB can still lock/unlock the door with the buttons on the FOB. Even the passenger side keyless entry works. The problem is only on the drivers side door. Any suggestions on what can cause this issue? Thanks jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 9, 2023 Report Share Posted March 9, 2023 6 hours ago, Fayçal said: Hey all, In the last weeks the keyless entry on my drivers side door stopped working. This feature usually unlocks my door when I place my hand in the door handle and locks it when I press the button on the handle. This is the only feature that has stopped working; the actual key FOB can still lock/unlock the door with the buttons on the FOB. Even the passenger side keyless entry works. The problem is only on the drivers side door. Any suggestions on what can cause this issue? Thanks 5rebel9 has replied to what i would also believe is to be your problem larryl 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 9, 2023 Report Share Posted March 9, 2023 It could also be the wire harness from the car body into the door Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 10, 2023 Report Share Posted March 10, 2023 2 hours ago, larryl said: It could also be the wire harness from the car body into the door Guess it could be But since the key fob unlocks the door lock BUT the hand touch doesn't would lead me to think the wires at the handle are the most likely culprit larryl 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 10, 2023 Report Share Posted March 10, 2023 Agreed but those wires would be part of the harness no? 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 11, 2023 Report Share Posted March 11, 2023 but since the hand touch sensor seems to be the only thing not working it could just be the wires that are disabling it to work and the key fob is still working as well,, but i am not sure on all this but that would be where i would look first Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 11, 2023 Report Share Posted March 11, 2023 Since the harness wires from the handle do go back to the BCM, there is a remote possibility of a broken wire in the rubber boot at door to body. BUT since both have been posted of, the OP should be able to determine now as to where to look...IF the OP ever responds back. Fayçal and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
