brutalzombie94 Posted March 11, 2023 Report Share Posted March 11, 2023 Hello all, not sure if anyone else has come across this problem but I have p1004 code which is for the manifold control runner short valve. I have already replaced BOTH of the manifold controller's. Code still didn't go away even after clearing the codes. Ended up buying a used Manifold Intake due to the plastic piece that the short runner valve sits in was broken. I put both brand new control valves on the new manifold intake I bought but even after changing out the manifold intake the code is still showing. Could it be electrical? I also noticed when taking out the old manifold that the 2 bolts in the back were not even on there and one side is missing a bracket, not sure that would really effect the manifold intake though, would it? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 11, 2023 Report Share Posted March 11, 2023 I would ASSUME you are working with the 3.5 V? YES it could be electrical wiring between the control valves OR even possibly into the PCM itself. I doubt the missing bolts/bracket has anything to do with the situation, particularly if this has been a RECENT{and not an old ongoing} problem. Quote Link to comment Share on other sites More sharing options...
brutalzombie94 Posted March 11, 2023 Author Report Share Posted March 11, 2023 8 minutes ago, 5rebel9 said: I would ASSUME you are working with the 3.5 V? YES it could be electrical wiring between the control valves OR even possibly into the PCM itself. I doubt the missing bolts/bracket has anything to do with the situation, particularly if this has been a RECENT{and not an old ongoing} problem. Yes it's the 3.5l and what is PCM? Sorry I know some stuff but not alot. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 11, 2023 Report Share Posted March 11, 2023 PCM.... Power control Module ... In simpler terms the engine computer. NOT a plug in and play part{needs to be programmed to the car to work} , Check wiring first. Quote Link to comment Share on other sites More sharing options...
brutalzombie94 Posted March 11, 2023 Author Report Share Posted March 11, 2023 1 minute ago, 5rebel9 said: PCM.... Power control Module ... In simpler terms the engine computer. NOT a plug in and play part{needs to be programmed to the car to work} , Check wiring first. Thank you so much! I greatly appreciate it! Will definitely check the wiring to see if I notice anything. Quote Link to comment Share on other sites More sharing options...
