Shift interlock solenoid 19 Journey 2.4L SE
Hello guys,
Please can someone direct me to where shift interlock solenoid is located in 2019 Dodge journey.
My DJ always shows "R" in the cluster when it parked. Also, always show reverse when i'm driving.
Sometimes, it will not shift out of park when i press the brake. All my brake lights are working fine.
I have replaced the following:  floor shifter assembly, shifter cable, Range Sensor.
The Range sensor was inside the valve body in the transmission fluid pan. Maybe i should change the complete valve body?
Any advise will be greatly appreciated.
