2010 journey sxt crossmember specs?
Welcome to the site. Looks like 100 foot pounds. If you use the very awkward search program it will come up with this chart.
Front suspension:
DESCRIPTION
N·m  Ft. Lbs.  In. Lbs.  COMMENT
Brake Shield  10  7  89
Crossmember Mounting Bolts  135  100
Crossmember Reinforcement Bracket Mounting
Screws
50  37
Hub And Bearing Mounting Bolts  48  35
Hub Nut  160  118
Lower Ball Joint Stud Nut  95  70
Lower Control Arm Front Pivot Bolt  175  129
Lower Control Arm Rear Pivot Bolt Nut  145  107
Stabilizer Bar Cushion Retainer Screws  60  44
Stabilizer Bar Link Nuts  48  35
Strut Clevis-to-Knuckle Nuts  140  103
Strut Rod Nut  60  44
Strut-to-Tower Nuts  55  41
Tie Rod Adjuster Jam Nut  75  55
Tie Rod End Knuckle Nut  85  63
Wheel Mounting (Lug) Nuts  135  100
