Will they fit? 235/65/R17 17x7 ET51
irodd
I have found a good deal on 2022 Chrysler Pacifica wheels: tires 235/65/R17 rims 17x7 offset +51
Anyone have an experience with them?
Yes, I know I have to try a fitment before buy but it is 50+km from my place :(
Edited by irodd
12 hours ago, 2late4u said:
call your local dodge dealership they will know for sure
I called 2 dealerships. They even do not understand how it possible to ask such questions.  It is not safe to do something what is not in the user manual.
On 4/7/2023 at 2:48 PM, jkeaton said:
They will be fine. The wheel specs are the same and the tires are 1/2" taller and less than 1/2" wider. Will make your speedo off by 1 mph at 60.
My concern was the different offsets: +40mm on OEM Dodge rims vs +51mm on Pacifica rims.
So all that +12mm of width goes to the inner side, very close to the shock absorber. And a negative scrub radius.
But short test drive was OK.
On 4/7/2023 at 9:55 AM, irodd said:
225/65R17 17x6.5 +40
Oh, my bad. I was not paying attention to this reply and thought these were the specs of the new wheels. You are correct. I guess since you got them mounted, you will find out. They look good.
