irodd Posted April 6, 2023 Report Share Posted April 6, 2023 (edited) I have found a good deal on 2022 Chrysler Pacifica wheels: tires 235/65/R17 rims 17x7 offset +51 Anyone have an experience with them? Yes, I know I have to try a fitment before buy but it is 50+km from my place Edited April 6, 2023 by irodd Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 7, 2023 Report Share Posted April 7, 2023 call your local dodge dealership they will know for sure Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 7, 2023 Report Share Posted April 7, 2023 Whats the size on it now? Quote Link to comment Share on other sites More sharing options...
irodd Posted April 7, 2023 Author Report Share Posted April 7, 2023 2 hours ago, jkeaton said: Whats the size on it now? 225/65R17 17x6.5 +40 Quote Link to comment Share on other sites More sharing options...
irodd Posted April 7, 2023 Author Report Share Posted April 7, 2023 12 hours ago, 2late4u said: call your local dodge dealership they will know for sure I called 2 dealerships. They even do not understand how it possible to ask such questions. It is not safe to do something what is not in the user manual. Quote Link to comment Share on other sites More sharing options...
larryl Posted April 7, 2023 Report Share Posted April 7, 2023 Drive the 50klm's take one off your front wheel and try to put one of those on... it would answer your question pretty quick Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 7, 2023 Report Share Posted April 7, 2023 They will be fine. The wheel specs are the same and the tires are 1/2" taller and less than 1/2" wider. Will make your speedo off by 1 mph at 60. 2late4u and larryl 2 Quote Link to comment Share on other sites More sharing options...
irodd Posted April 9, 2023 Author Report Share Posted April 9, 2023 On 4/7/2023 at 2:48 PM, jkeaton said: They will be fine. The wheel specs are the same and the tires are 1/2" taller and less than 1/2" wider. Will make your speedo off by 1 mph at 60. My concern was the different offsets: +40mm on OEM Dodge rims vs +51mm on Pacifica rims. So all that +12mm of width goes to the inner side, very close to the shock absorber. And a negative scrub radius. But short test drive was OK. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 10, 2023 Report Share Posted April 10, 2023 On 4/7/2023 at 9:55 AM, irodd said: 225/65R17 17x6.5 +40 Oh, my bad. I was not paying attention to this reply and thought these were the specs of the new wheels. You are correct. I guess since you got them mounted, you will find out. They look good. Quote Link to comment Share on other sites More sharing options...
irodd Posted April 12, 2023 Author Report Share Posted April 12, 2023 After 200km no any problem found. It fits. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
