17JourneySXT Posted April 23, 2023 Report Share Posted April 23, 2023 Good Evening, I have a 2017 Dodge Journey SXT 2.4 L, I had the common plastic T behind the engine cracking/breaking and it was repaired about a month back and the coolant has been replaced and air pockets have been bleed from the cooling system. Recently I was driving at about 70 mph for closed to 1 - 1.5 hours on the interstate and the outdoor temp was between 50-60°F. I was questioning the temps because my Coolant would peak at 208-210°F with heat on and without heat/air on it would peak at 221°F and would begin to drop when it got to this point. About 30 minutes into the drive the Engine oil got to 210°F and with heat off it got to 221°F but didn't go any further. On the digital thermostat when it reached 221°F it was like one notch below the red H. My transmission temp ran at around 130-145°F during the drive. Lastly, the analog thermostat guage stayed directly in the middle and would slightly move a little to the right (warmer) but that was when the coolant was at 221°F. Personally at least from everything I can find, it seems fine however I was concerned that the oil may be a bit high as well as the coolant getting to 221°F. I was wondering during if there was an actual Ideal/Normal temp range that everyone recognizes because before the T broke, I wasn't actively checking these temps so I'm not sure what temps it was running at before. I can't really find anything online that's says an exact temp range for each, and I'm not seeing a range in my manual as well. I've done a couple troubleshooting steps as well. I've filled my coolant resivoir to the MAX line and held it steady at 2 RPM while in park once the analog guage reached the middle to try to bleed out any hidden air pockets, the coolant resivoir level didn't move. I'm pretty sure the radiator fan is working because it turns on if I turn on the AC. I've changed the engine air filter early as well as the cabin air filter, and did an early oil change (full synthetic). I would appreciate any assistance with identifying if this is normal, I think I'm truthfully just worried due to the issue with the T breaking previously and want to make sure I'm taking every precaution, and not neglecting it. I appreciate and thank you for your time! Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 23, 2023 Report Share Posted April 23, 2023 i have the 3.6 but had to replace my thermostat with around 140 k on it, and ya i kept a real close eye on it as well, i used an after market thermostat instead of OEM and before the change i usually ran around 195 at normal and around 112 at high temp.NOW it usually runs around 200 or so and have seen it while it was hot hot running as high as 212-215 and then drop back down to 205 then fluctuate back and forth, also used the correct mopar antifreeze required. if your not happy i believe the actual thermostat can be removed from the housing and a slightly lower spring unit put back in, also you could also add a extra cooler to the system. hopefully some one that has the 2.4 can post some of their readings for you, but some of your readings do sound a bit high. good luck and welcome to the group Quote Link to comment Share on other sites More sharing options...
Jaquenette Bernard Posted July 12 Report Share Posted July 12 With these tea problems I just had one as well why hasn't they been on recall yet or have they I have a 2019 Dodge journey are the t's on recall cuz mine was plastic as well and I've replaced it with another plastic one what should I do? Quote Link to comment Share on other sites More sharing options...
pickle Posted December 13 Report Share Posted December 13 A normal coolant operating temperature for a 2019 Dodge Journey 4-cylinder engine is typically between 195°F and 220°F; this means the temperature gauge on your dashboard should generally stay within the middle range, indicating a healthy operating temperature. Quote Link to comment Share on other sites More sharing options...
