jas Posted May 1, 2023 Report Share Posted May 1, 2023 I have a 2017 Dodge Journey Sometimes when I turn the vehicle on the radio is vey noisy and you hear lots of static I turn the vehicle off for a few seconds and then on again. The problem goes away. This is seldom occurrence. It is really annoying when the radio is off, turn the vehicle on then drive and turn the radio on and then hear all the noisy static. I then need to pull over and turn the vehicle off to clear the noise Anyone have any ideas or suggestions Thanks Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 1, 2023 Report Share Posted May 1, 2023 possibile your antenna connection might be loose at the radio , there is a noise suppressor you can buy for such problem if it is and interference problem from the engine,BUT this should not be necessary as you have a problem somewhere and should be checked out either thur the dealership or maybe a local car radio shop which should be cheaper,,when you find the problem please report back for others that might come up with this problem Quote Link to comment Share on other sites More sharing options...
Cruz Posted September 24, 2023 Report Share Posted September 24, 2023 Same thing happened to me earlier today on my 2018 journey. Before I could pull over to turn mine off, the radio restarted itself. Both the touchscreen and physical buttons were not responsive. I was thinking there could be an update available for the firmware and it most likely is software related if a reboot made it go away. I’ve had the truck for about 7 months or so Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 24, 2023 Report Share Posted September 24, 2023 15 hours ago, Cruz said: Same thing happened to me earlier today on my 2018 journey. Before I could pull over to turn mine off, the radio restarted itself. Both the touchscreen and physical buttons were not responsive. I was thinking there could be an update available for the firmware and it most likely is software related if a reboot made it go away. I’ve had the truck for about 7 months or so no robot what what i have ever heard Quote Link to comment Share on other sites More sharing options...
