2018 Dodge journey gt
Tallguy40
  On 6/7/2023 at 6:44 PM, Tallguy40 said:
But doesn't explain why I have cold blowing on one side and hot on the other
Expand
A broken / bad actuator may have failed in the "hot" position for the passenger side. This is also true for A/C usage as A/C temp is controlled by the blend door actuators. There is a blend door for driver and another for passenger side on models with "dual zone" front temp adjustment{which most all DJ's have}.
IF these are working, then there is the POSSIBILITY that A/C refrigerant is low on charge.
You have been given the correct video and suggestions on what to check first.
