Jmgerow Posted June 20, 2023 Report Share Posted June 20, 2023 Recently replaced TPMS Module in wife's 2018 Journey due to dash displaying - - - as air pressure for one tire, despite that particular tire being moved from LR to LF. However, after several daily drives, nothing's changed. Now I'm uncertain about how to proceed with diagnosing, as well as lacking a list of any likely culprits. Attached below are screenshots of the relevant codes (as read by BlueScanner scan tool). Please assist if able, and I'll be sure to report back with what the eventual solution is. Quote Link to comment Share on other sites More sharing options...
larryl Posted June 20, 2023 Report Share Posted June 20, 2023 I had the same issue replaced the module still the same result Put the summer tires on and everything works as normal now....crazy Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 20, 2023 Report Share Posted June 20, 2023 i have a 2014 and was having problems with one tire not registering and then working for a bit then not working again,i moved it to a different spot on the journey but it didnt move with the position change, i was going to check the module but never got around to it, and then had my journey checked at the local Discount Tire shop on 2 different times for the tpms and they said the first time they were good and then 2 weeks later they said 2 of them were bad.i had them replace all 4 of them and that fixed the problem... even tho yours is a 2018 that might be the problem i would just replace the one you are having a problem with.. good luck Quote Link to comment Share on other sites More sharing options...
Jmgerow Posted June 21, 2023 Author Report Share Posted June 21, 2023 Thanks for the info, guess I'll have to try the sensor in the tire that was originally in the RL position. Anyone happen to know if it's much cheaper to buy the core tool, etc. and do it myself versus paying a mechanic? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 21, 2023 Report Share Posted June 21, 2023 depends if you have the tools and to remove the tire and install the sensor that part is easy then reinflate the tire and then use a scanner to initiate the tpms to the computer...be careful as there are different types of tpms and the way they install and if the have to be scanned or plug and play.....the tire store did tell me that inflating a tire and deflating the tires are what cause the tpms to wear the battery out..as i said mine were org from 2014...PLEASE report back on what you find to be your problem for others to learn from Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted June 22, 2023 Report Share Posted June 22, 2023 You MAY want to look up the "running"{current} thread topic ... TPMS failure. Myself and a few other active members have been discussing our same concerns and the possible cause/repair needed. There can be multiple reasons WHY a system may malfunction. 2late4u and larryl 1 1 Quote Link to comment Share on other sites More sharing options...
