Power Window reset
BUGS
If the express up and / or down fails to operate at the second indent on the PW switch it can be reset.
Hold the switch until the window rolls up and stops and hold the button for 2 more seconds (you may here a click in the door under the switch).
Then hold the switch down until the window rolls completely down and continue holding the switch for 2 more seconds. You will hear the click again.
TaDah the switch is reset.
