davidhoudek Posted June 4, 2010 Report Share Posted June 4, 2010 I have a question, I have a 2010 Deep Blue Water Journey, whenever I use my automatic started from my home to start car up and get into car and put key into ignition, it says low tire, but when I start it with using ignition only, I dont have that issue. I checked my tire pressure yesterday and it was reading 44 PSI, and it says it need to be 32 so I took care of that yesterday and I got the same issue today. I have had the car for almost 4 months and I have 1,542 miles on it. Does anyone recommend anything? Is this covered by warranty? Quote Link to comment Share on other sites More sharing options...
Swerv Posted June 4, 2010 Report Share Posted June 4, 2010 On 6/4/2010 at 2:22 PM, davidhoudek said: I have a question, I have a 2010 Deep Blue Water Journey, whenever I use my automatic started from my home to start car up and get into car and put key into ignition, it says low tire, but when I start it with using ignition only, I dont have that issue. I checked my tire pressure yesterday and it was reading 44 PSI, and it says it need to be 32 so I took care of that yesterday and I got the same issue today. I have had the car for almost 4 months and I have 1,542 miles on it. Does anyone recommend anything? Is this covered by warranty? Could be a problem with the link between your remote starter and your vehicle. I am just speculating here but just as when you first start a vehicle all the lights will light up to show you that they are all working in case one is burnt out... Well maybe when you remote start something causes the light for the tire pressure to remain on? Could be the way its wired to the cars on board computer. I would contact the guys that installed it because i believe any sort of modification you did thats causing this to happen probably wont be covered under your vehicles warranty but hopefully the shop that installed it has a warranty on their work. Quote Link to comment Share on other sites More sharing options...
warbird24 Posted June 5, 2010 Report Share Posted June 5, 2010 As Swerve stated, I'll bet it is in the remote circuit. Is it a FACTORY Installed or Aftermarket installed Unit? If it is the Factory Unit, of course they will look it over. The Aftermarket one is only going to be as good as the install shop that did it. If they are reputable, they will stand by it and try and make it good for you. Good Luck Quote Link to comment Share on other sites More sharing options...
Swerv Posted June 5, 2010 Report Share Posted June 5, 2010 On 6/5/2010 at 12:20 PM, warbird24 said: As Swerve stated, I'll bet it is in the remote circuit. Is it a FACTORY Installed or Aftermarket installed Unit? If it is the Factory Unit, of course they will look it over. The Aftermarket one is only going to be as good as the install shop that did it. If they are reputable, they will stand by it and try and make it good for you. Good Luck This thread reminds me of this one time i was at Casino Morongo in California and we were having a contest who could remote start their vehicles because we were way up in the tower and i could see my vehicle's lights blink to show it had remote started. Problem was i couldnt turn it off lmao so i had to go down the elevator and all the way to the far end of the parking lot to make sure it was off and locked. Quote Link to comment Share on other sites More sharing options...
davidhoudek Posted June 7, 2010 Author Report Share Posted June 7, 2010 On 6/4/2010 at 5:34 PM, Swerv said: Could be a problem with the link between your remote starter and your vehicle. I am just speculating here but just as when you first start a vehicle all the lights will light up to show you that they are all working in case one is burnt out... Well maybe when you remote start something causes the light for the tire pressure to remain on? Could be the way its wired to the cars on board computer. I would contact the guys that installed it because i believe any sort of modification you did thats causing this to happen probably wont be covered under your vehicles warranty but hopefully the shop that installed it has a warranty on their work. Quote Link to comment Share on other sites More sharing options...
davidhoudek Posted June 7, 2010 Author Report Share Posted June 7, 2010 The remote started came with my car when I purchased it, so would I just contact the dealership and have them to look at it? I wonder if it will be covered Quote Link to comment Share on other sites More sharing options...
