kered118 Posted June 28, 2010 Report Share Posted June 28, 2010 hi, i have problem installing the rear disc pads anybody can help? thanks Quote Link to comment Share on other sites More sharing options...
warbird24 Posted June 28, 2010 Report Share Posted June 28, 2010 Bet you are having a problem with clearance and getting the piston back in. The Calipers are self adjusting on these cars and require a special tool to SCREW Back in the caliper piston. These tools can either be bought or be rented at AutoZone stores if you have one around. I am sure Napa, Pepboys and the rest also have the tool available for purchase. Make sure you clean the caliper off and put some lube on the piston so it screws back in smoothly. Many forget to do this step and wind up with problems later due to the caliper hanging up. Hope this helps... Quote Link to comment Share on other sites More sharing options...
