Damaged Floor Bin
Olaf L.
The driver side floor bin has been crumpled by running the Journey over a median. Can the bin be "popped" out and replaced with a new one or is it part of the floor of the vehicle? I see four bolts on the inside lip of the bin, but when I look at the bin from underneath I can't see a "seam". Any help would be greatly appreciated.
I do not know if the bucket comes out, likely not. Can it be punched back close to its original shape?, at least enough to allow the plastic bin to fir in. If so that may be your best option and then just coat the outside with undercoating and reseal the metal inside.
